The Targus TG-P60T is on clearance at my Target for 32.00 dollars, normally 64.99
I got this just because i can move the legs almost completely horizontal.
Check your local target if you want to step up from a basic ultralight tripod.
This is what i bought:
Merkury Innovations Targus 60 Tripod 3 Way Panhead Bubble Level Pro Series - ATS - Online Computer Store
EDIT: i just opened it. This thing feels HEAVY. I wont be taking this on any hiking trips, but wind would not move this thing at all.
Info from the manual:
TG-P60T
Max. operating height: 151.5cm / 60"
Min. operation height: 14.0cm / 5.5"
Folded Height: 58.5cm / 23"
Max. tube diameter: 23mm / 0.92"
Net weight: 1.6kg / 3.5lb
Max. load capacity: 2.25kg / 5.0lb
Reason: New info.
