It's a tip based on a lot of wind.
General statements about focal length, without regard for the actual lens being used, should be taken warily (as you do). There is no optical reason why this should be true. The effect of adding glass in the light path (which always, to some extend, degrades the image) is independant on the focal length.
Quite the contrary, ultra-wide angles are more likely to have polarizer issues, because the field of view is too large, and the polarizer"s effect will often be uneven.
