Well, one for two ain't bad.
You're right about the white balance: the target must be neutral (or very nearly so). The ExpoDisk isn't, but it's very close and they run a photo spectrometer on each one to get the amount it's off. Mine has density of .75; WB red=0.0, green=0.03, blue=0.03 measured to NBS standards. I've had a WhiBal card set for about three years; had to take the manufacturers word on it's calibration. Also got a Robin Myers Imaging Digital Gray card. Again, not an exposure reference--they tell you so, but something the maker claims to have a 'flat spectral response", i.e. neutral. I even have a set or warm-balance cards from digital video work--you can print a set for yourself that's modestly accurate if you color manage both monitor and printer and are fairly adept at using google to find the web site.
WB does seem to matter regarding the RAW vs JPEG debate--it's not a fringe issue, nor is it known
why or
how much it effects the outcome; photographers lack the patience and equipment to make an accurate determination. There is some variance camera to camera or I'd tell you mine.
Suffice it to say, one should ALWAYS perform a WB step in ones workflow in-camera.
You're wrong, or more precisely "you're perpetuating the myth of the Gray Card" along with Papou.
Interestingly, Kodak GrayCards have their 'typical spectral response" listed on their instruction sheet. And they are remarkably neutral! (Draw your own conclusions.) They have flaws: they fade and shift with time as they are manufactured on cardboard with normal printer's inks. They are NOT a standard shade of gray, they are NOT a
standard target! THEY ARE A REFERENCE TARGET: something, unlike skin for example, that doesn't change much over either a short period of time or a long period of time. They ARE NOT consistently 18% or middle gray,
nor do they need to be.
They don't relate directly to the cameras calibration, which incidentally might not actually be 18%/middle gray either! You set exposure off a gray card 'directly' at your own peril! More appropriately, you set exposure of
any handy
reference target by knowing how much to correct from the meter reading to make the reference look normal. THIS REQUIRES CAREFUL EXPERIMENTATION AND NOTE KEEPING AS IT VARIES FROM CAMERA TO CAMERA AND LENS TO LENS. {I will not apologize for shouting! This is important material! Ignore it at your own risk! Continue the myth, NOT!}
WB doesn't actually require a special target as the coffee filter set has demonstrated--it helps for those seeking technical 'perfection'. It's also not an 'end' in it's own right as far as color correction is concerned; you need a ColorChecker type device, more software and response curves and profiles to take that step. Over my
digital career, I've used T-shirts, white walls, gray walls-anything that I was sure I could easily match on both the LCD and remember accurately once I returned to the computer.
Proper exposure doesn't require a gray card; you must however know
how your meter reads and
how your camera shoots and
that does require careful experimentation at least once. Any handy
reference target will do: your hand (palm-it doesn't change much or fast re color/reflectivity) the jeans you wear, the side of your camera bag. Or you could learn the zone system scale and have a whole list of reference targets and target tonal values-that will require some real effort; is the digital shooter up to this task?
Originally posted by and I dont mind at all. I have heard about the palm method, and I beleive its a given that its not a 100% scientifically correct method, but rather a handy replacement for a greycard if you dont have one with you, which seemingly will work well in several conditions. I guess the most important one being outdoors where the sun is lighting everything the same way. People have different skin colors and different skintones (varying degrees of tan for instance) so its not a very scientiffic reference.
As for exposure with the whibal, I just tested it briefly, the pocket version I have being a bit small for this use, and I didnt find the results to be all that great.
Now, if you watch the videos, it is being stressed that WhiBal is a white balance reference card, not a greycard. Some greycards are designed for exposure, some are not.
Im not an expert, but I will tell you what I think. A grey card made for exposure needs to be 18% grey, or middle grey (mid tone) because that is what the spot meter gives you the reading for, middle tone.
A white balance card, does not have to be 18% grey, it just has to be neutral (R G and B all having the same value) so a card that is 100,100,100, is not middle grey and will not give the correct exposure with a spot meter, but it is neutral and will be correct when used to set white balance.
The WhiBal was not made to be middle grey, it was made to be light grey, because the image sensors capture more data in the light tones of the image than the dark ones, so having it light means you will get more data on it, but they didnt make it close to white, altho that would also have worked for white balance, because if it was white, then it might clip if you overexpose a bit.
So, as for the WhiBal, no its not advisable to use it for exposure, because it is not middle grey.
