Hey all. Not that this is the most spectacular DIY, but I figured I would share. I purchased the 62" Dolica tripod, and although I loved it, it would be nice for it to play two roles, a normal height tripod, and a mini tripod. Since the tripod has about a 12" pole, it makes it hard to get low with it.
I solved this by removing the pole and building another insert. This requires no cutting, or any changes to the tripod. This will not hurt or damage anything to the tripod and is 100% reversible. Takes less than 5 minutes.
Required hardware
2x 3/8 x 1.5 rubber washers
2x 3/8 x 1.5 metal washers
1x 3/8 x 2.5 bolt
1x 3/8 nut
Remove the hook from the bottom of the pole (just unscrews)
remove the pole from the top and unscrew the ball head. Build the new mount (Bolt, washer, rubber washer, through tripod, then rubber washer, washer and nut.) I just hand tightened them, you dont want to crush the plastic.
Success. now just mount the ball head and camera.
Before... (remember this is alot higher, i forgot to attach the ball head for the pictures, so add a few inches for that)
After.
