Yeah, PL. I have a preference for the Gitzo-like twist-type: they work from any angle and there's less to get snagged on things or be uncomfortable to carry (or catch my hair. One less thing that might do that is always good.
) But, for all that it's not really that strong a preference.
With the Benboes, the legs are skinny because there's generally only two sections, but that also means they should be plenty strong, at least. Kind of a different design than usual. It has advantages and disadvantages: I like the fact that at least you don't have to bend over, and they're quick to set up, but they also are usually kind of long to carry, I'd think. I've only actually seen the rather bigger ones in person, so I'm not sure how the more portable designs work out. The main thing I don't care for is that the arm bit isn't directly on-center, which might be OK if you really want the low angle stuff, but isn't the stablest possible for the kind of stuff I do.
I might think it's worthwhile if I could check em out in person for size and stuff: my rationale is that what usually happens when I'm using a tripod is that I'll generally extend the legs once and then just prop it on my shoulder as I move around (Just in case you were wondering how to get leg clamps in your hair.
) Anyway, they're kind of a different arrangement, so directly comparing the look of them to other designs might not really apply. Anyway, for what that's worth at this point. They're kind of weird, but it's a pretty functional weird.
Anyway, my big tripod has flippy-locks, they're not so bad, though it's kind of possible to end up trying to push them the wrong way, which I find a minor annoyance. I think a lot depends on the particular design with those, whether I like them or not. I think Sliks are usually OK that way, and people seem to like that one.
