01-31-2011, 08:05 PM   #1
johnny9fingers's Avatar
OM focusing screen on K20D?
Will a focusing screen from an Olympus OM fit a K20D?
01-31-2011, 08:53 PM   #2
Not without modifications, it won't. You'll have to cut the OM focus screen to K20D screen's dimensions and shim to match the thickness if the P20D screen happens to be thicker than the OM screen. I am in the process of doing what I have described above with a Canon AE-1p focus screen because it was considered as one of the brightest screen Canon manufactured for their FD mount camera lineup.
01-31-2011, 11:22 PM   #3
ovim's Avatar
I'm using a screen from a an old Pratktica SLR in my K-r. Here's what I did: after removing the screen from the old SLR I covered it with tape from both sides to prevent scratches. Then I drew the outline of the pentax screen on the tape and filed carefully until the screen was the right size. After installing the screen I noticed I needed some shims because the focus was a bit of. I used thin strips of clear tape on the edges of the screen to act as a shim.
"Calibration" took some time. Here's how I did that:
After adding tape strips ->install screen to take a shot of a test chart-> take the screen out to add a few more tape strips-> install screen and take a new test shot...
I repeated this until the focus was spot on and now I trust it more than the focus confirmation of the body.
02-01-2011, 04:35 AM   #4
joakimfors's Avatar
How much does metering get affected when using a brighter screen? Is it a big problem or do you just not care?
02-01-2011, 09:20 PM   #5
QuoteOriginally posted by joakimfors Quote
I don't think metering is affected by brighter screen and Rachel Katz of KatzEye seem to concur. I was interested in purchasing a plain matte screen with Optibrite treatment to replace my standard screen on the K20D, but the $160.00 price tag quickly scuttled that idea and instead I have bought a used KatzEye screen (no Optibrite) with split prism in the centre, which is a big nuisance for me. What does affect the metering is the center split prism, which renders spot metering useless. I found an AE1-p screen for 10 bucks and if it turns out to be brighter than the KatzEye screen, it could only help in focusing manual lenses while stopped down.
Thanks,
om, screen, tripod
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
Focusing Screen for K20D Vasyl Pentax Camera and Field Accessories 14 09-07-2010 03:52 PM
For Sale - Sold: Pentax Brand Focusing Screens and Katz Eye Focusing Screen K10D/K20D (Worldwid superbass Sold Items 8 03-26-2010 01:42 PM
Li-80 K20D Focusing Screen? Blue Pentax Camera and Field Accessories 3 06-22-2009 06:07 PM
K20D and interchangeable focusing screen wildman Pentax DSLR Discussion 1 06-12-2008 08:44 PM
All times are GMT -7. The time now is 07:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
