Remote Assistant version 1.0 works with my K100D (firmware 1.02). Two settings are required though:
- The quality must be set to RAW. The Assistant always saves a .PEF file and if the quality is not RAW, only thre preview image works but you get garbage as the main image content.
- The instant preview must be set to "Off". If I leave it at my normal setting "5 sec", the operation is unreliable.
I also use the combination of "Auto Save" and Picasa which results in a direct display of the image after a short transfer delay.
Greetings to all K-7 users.
