Originally posted by krp I was thinking of buying this tripod:
Slik Sprint Mini II GM 4-Section Tripod w/ SBH-100DQ 611-806 B&H
Does anyone have any experience with it? I was going to buy a Dolica tripod, but then I realized I would use a tripod a lot more if it was small so I could bring it everywhere. I often go on bike rides and this looks easy to throw in a backpack. I know the Slik Sprint Pro II seems to be recommended often here. But that one is bigger and more expensive. I have a K-x, Tamron 17-50 f2.8, Pentax 55-300 and I don't plan to buy any bigger lenses for awhile. Do you think this tripod would work with this setup?
I use the predecessor model. Overall, it is a great price/performance tripod. I'm a fan of the carry-on only travel style, and it's the most tripod I can get on-board.
You should be fine with the lenses mentioned. As lenses approach 2lb/1kg, the torque becomes too much for the ball joint.
There is flex in the legs, particularly when extended. This makes it no good for windy conditions. At full extension and 300mm zoom, you might also see some very minor lingering shudder from the mirror lock up after 3 seconds. I sometimes use mine as a 16x binocular mount, and it takes forever (8-10 seconds) to settle from a tap on one of the struts.
