Originally posted by Ratmagiclady I think John Flores there might have your simplest solution, but how would something like this do you?
Acratech GP Ballhead*::*Ballheads*::*Acratech
Kinda pricey, this one, but you can use this one for a pseudo-gimbal if you have a lens with a collar or whatnot, and it can like flip upside down to be a levelling pano head, and, yeah, it's still a ball, but it seems it might do what you want and be of a piece.
But the site might give you some ideas, too.
There's always the cheaper solution of a 3-way head and a couple of plumb lines hung alongside the column, ie, work to get the tripod level and then just use the pan-head.
I started out with a plastic/aluminum tripod with a clunky 3 way head that I got off of ebay for 11 cents. Hated it, but learned what I liked and what I could not tolerate. I found a reasonable travel weight and sized tripod that I am currently using (Benro travel angel) and like - but it came with a freebie ballhead that I used once, hated it (just one lock down level) and again started looking. I spent an enormous amount - a small fortune on the Acratech GP ballhead. For me it was the perfect solution - and you will have to pry my dead hands off of it - its that good (YMMV...). Inverted - it is the perfect panning head (for single row panoramas). The gimbal is wonderful - maybe only 98% perfect - but good enough for me - holds the K20 with the 55-300 lens or my very heavy K 28 shift lens. Anyway - its rated to hold 25 lbs.
Originally posted by les3547 I had similar frustrations until I read a pro photographer recommending a type of ball head that cost what I thought was an outrageous price. The one I went with is a Vanguard, the ABH-120L Semi-Elliptical Ball Head (it cost less than what the pro recommended but was still about $200), and claims to hold 40 pounds. My thoughts were if I have a ball head that holds far more weight than I use, then the tensioning feature would hold the camera better where I place it.
And sure enough, tension it at the right spot and you can move your camera around or turn it to any angle, and it hold its place faithfully.
What I thought was an outrageous price I now see as the price that's paid for such precision and capability. The way it's made it might last a lifetime too.
The second variable tensioning / friction knob is the key, I found. The GP and Les' Vanguard operate very similarly. I too have found that you get what you pay for.
I wound up getting a second used tripod - a Manfrotto 3009 pro - that came with a Manfrotto ballhead - a 486RC2, I think (the price was great). I absolutely hate and despise that 486RC2 &%$#@*!% as much as I like the GP. Why - because it flops around - just one clamp down lever - no friction adjustment and the quick release clamp requires 2 hands (at least for me to operate) and the camera goes falling off. Looking for a replacement. I would buy a second GP but the $400 bucks is just tooooo expensive for a second one (as much as I would like to have another).
I picked up the second used tripod to support a full pano head - the Nodal Ninja 3 that works like a charm - for multi row panos. The NN3 has a rotating base, so all I really need is a leveling base (and that is probably what I will end up with). I have 2 tripods for my 2 camera bodies (K100 and K20) - because when I was using the NN I always saw another shot that I could have taken with my other body, however it was always too dark to hand hold - if I only had another tripod......
The GP only takes about 10 second to setup, level in all directions, and I get perfectly level panos - first time, all the time, and its so easy - no fumbling with leveling the tripod legs out (I could get close but not perfect - and wound up with a lot of panos that went either up hill or down hill.
The moral of the story - good mechanical support that operates well is neither cheap nor inexpensive.
