Just trying to get an idea of what many use here as a messenger style bag for travel. I currently own a Crumpler 8 Million Dollar Home and it's a great bag ( from my Nikon days ), but as I gradually put together my Pentax Kit, I can tell it's made more for a large camera like a D700 and a couple of large zooms, two large primes and maybe a flash.
I am in the process of switching to an entirely prime setup. I don't shoot much sports. Mostly street photography, portraits, landscapes, and macro. I am looking for a bag that will not only hold the following equipment, but will also make getting to the lenses
relatively easy.
The crumpler, is a very deep bag, so toting around 5-6 primes is going to result in the need for stacking them, and that isn't the best way to work with primes. So.. here is my question. What bags do you guys like that are great for carrying around multiple primes and allow for relatively easy retrieval?
My goal is to find something that will..
Hold the following
K-5
15mm Prime
31mm Limited
50mm 1.4
70mm Limited
100mm Macro
300mm F4 ( most likely the older manual focus version )
- Not a stiff material. The crumpler is built very well, but the material is very stiff
- Comfortable shoulder strap that you can wear for hours and not feel like your neck is being ripped off ;-)
Any suggestions? Thanks for the help.
