Originally posted by MNCurt-K10D Last evening, it seems that my new AF-360FGZ forgot how to do wireless P-TTL... The flash works fine on the camera, and was working in wireless mode, then, between two shots, it stopped.
It doesn't even seem to work in slave mode (it fires, but seems to be out of sync with the camera as the recorded image is under exposed). Any suggestions?
So does it fire but making poor images? or does it not fire at all? Does it work normally when connected to the camera?
If it is firing, and it's just underexposed flashes, check your camera's flash compensation (not the flash unit's).
If it's not firing at all, I'd try to use a different channel to test it. Plug in flash, turn on in wireless mode, change channel to something else via flash unit, turn on camera, half press shutter.
