I think you should follow corfa's example & do a more quantitative assessment. Lithium batteries while expensive can perform extremely well depending on the application.
Total energy stored for Li-ion is noinally about 1/3 more than common batteries, but that's not the whole story. Li -ion batteries hold their voltage for much longer than other batteries so if your device stops working when the battery voltage drops below about 1.2V or the device draws a large current the Li-battery will last about 2-3 as long as others. This depends on the device; it won't make much difference for an led flashlight but it might make a big difference for a gps.
Here's a graph illustrating the differences:
Battery Life
