Okay, I've just about had my fill of rechargeable AA's. Just a few days ago, I used a fully-charged set of Kodak 2500mah AA's (just bought 2 weeks ago and charged 3 times before this) and took over 1000 shots at the Atlanta Zoo on one charge. Admittedly, I didn't use autofocus for about several hundred of those shots, but I did use the LCD screen to review a lot, so good performance overall. I recharge the set that night in a Kodak 1-hr charger (with a light that goes out when they're done), and the next day go out to Stone Mountain park to take shots there. I started the day with another set of batteries (Duracell 2650mah AA's), but when the laser light show was starting up that night, I set up to do a bunch of bulb-mode shots so I changed out the set I started out with for the exact same Kodak's that I had just recharged less than 24 hours ago. I get FIVE 3-second exposures out of them before "battery discharged" flashes on my LCD. Fortunately, I carry a set of regular CRV-3's for situations just like this & plopped them in and they lasted for the rest of the night's shooting. Needless to say, this and several prior experiences like this have gotten me to the point of shaving my freakin' head bald. I'm convinced that rechargeable AA's are just not reliable for the K100d, but I don't wanna just start using one-shot lithiums because of how much that can add up over time. So I see 3 choices on rechargeable CRV-3's:
Ultralast CRV-3's-I was able to find these locally for the same price, but they're rated at 2.4V, which is less than the standard 3V for CRV's, so I'm not sure how safe they would be to use in the K100d. Plus, they struck me as being a bit crappy when I looked over the packaging & such. They are the most inexpensive of the lot, and it would be easy for me to get 2 full sets.
Delkin-These are supposed to be the safest ones to use in the K100d as far as voltage is concerned, but they're also the most expensive of the choices I'm looking at.
Lenmar-These have a higher mah than the Delkins, and they're a little cheaper. I've also found them locally, but I have zero idea about their voltage.
I'm currently leaning towards the Delkins, but the price is a bit prohibitive as I'd like to buy 2 full sets of rechargeables, which would be almost $100 at that price. As I'm currently carrying 3 sets of rechargeable AA's, I was thinking of getting 1 set of rechargeable CRV-3's and carrying 2 sets of rechargeable AA's until I can afford to get a 2nd set of rechargeable CRV-3's.
So, anyone have an opinion on these particular CRV's? 'Cause I'm truly fed up with the AA's, and I can't get rid of them fast enough.
