Originally posted by yeatzee I am not jesting at all. Try doing this:
with what you have just purchased and come back to me :ugh:
172 images stacked ^ Perfectly normal for this type of photography
Impressive image! Is this your holy grail of macro photography? What was the stack depth between the first and last image or can you make an educated guess? I've seen your stacked macro images and they are quite impressive as well. I am more interested in achieving precisely focused, unstacked image out in the field with the Tamron 90/2.8 and I am certain these cheap rails would be more than sufficient for that.
As for the precision of these focus rails, without actually inspecting the unit I can't say. But if the rack and pinion's pitch is fine enough without slop, and if I can find a larger knob to replace or press over the pinion adjustment knob, I don't see why I can't make adjustments in increments of 5 degrees or so per revolution of the pinion. I've shot with a view camera enough where fine focusing is done under the dark cloth, with an 8 -10x loupe pressed against the ground glass while minutely moving the lens standard back and forth. I doubt these focus rail rack and pinion is as precise as my Linhof 4x5's, but one can only hope.
Thanks,
