Originally posted by tm01 I knew someone would bring up the three tripods rule! Alas, I feel that I am doomed to repeat it. I just can't spend that kind of money right now. This will be my second; my first very cheap tripod is in pieces. So I'm just looking for something lightweight and "good enough" to take backpacking.
The problem here is:
- if it is lightweight enough for backpacking it is either cheap aluminium alloy or expensive carbon fiber.
Cheap alloy will not stand up for long against the rigours of backpacking, YOU may lose a vital screw, because it is not secured against self-loosening or something will break or bend and you are left with a cheap useless heap of scrap metall.
There are some not too bad CF tripods, which may use older CF technology (6 layers instead of 8, not so nice finish) and can be found cheaper. Look out for the "Fancier" brand or one of its OEM cousins (Walimex, Amvona etc.).
On the other hand it might be wiser to go with a good table top tripod or clamp now and wait with the real tripod, until you have saved enough to buy a decent one.
Ben
