Originally posted by Rainy Day The adapter you found is for mounting M39 lenses on Kiev bodies. You'd need the opposite.
Lenses in Kiev Automat mount are cheaper than their M42 counterparts because they cannot be used on other cameras than Kiev 10 or 15.
Even if you managed to change the mount , the problem of controling the aperture would remain. At best, you could use the lens at full aperture only but J9 are quite soft @ f2 (soft-ish @ f2.8 and sharp @ f4).
I'm afraid it will be difficult to obtain a refund as the seller is quite clear that this version of the lens requires à Kiev 10 or 15 to be operated ...
Sorry to be the bearer of bad news
If you decide to bid on another J9, be sure it is M42 (M39 version exists in 2 flavors, for slr and for rangefinder, the latter being incompatible with your K7)
