Originally posted by zman Hi, I bike around often with my gear using a Kata DT-213 sling bag. It holds my K7 with my Pentax 18-250mm mounted plus has room for two additional lenses. It comes with a waist strap if you want it snug, but I go without it with no problem. It swings arond your body for fast & easy access to your gear. There is also a smaller model, DT-211 that may interest you. Protects everything well.
+1 for the DT-213
I bought the DT-213 specfically for a MTB trip in the mountains last year. Unfortunately other factors out of my control means 8 months later I still havent done the trip.
Anyway, I planned to use it as a torso pack with a backpack for other gear (it can attach to backpack straps)
I have done a short test with it and when in the front torso postion it's pretty stable and doesnt get in the way in normal open trails or riding on the road.
I carried k-7 with 55-300 fitted and some other prime lenses. (it can even fit the DAltd lens case). Personally i prefer to carry it on my torso as I felt it was less likely to get damaged if (when) i fall off. The padding/protection on these is very good.
The DT-211 is more compact and the latest version of the same sort of thing is called "LighTri?"
I also have a DW-493 waist pack which is a lot smaller and OK for riding providing you have it rotated behind you. Wearing it forward my (
muscular) thighs bump on it so not so comfortable. This is suitable for a K-7 and some primes. The 55-300 fits in but not when mounted to the camera.
If you arent planning to go on the really rough stuff, you might want to check out something like this
TopeakŪ Cycling Accessories ? Products - BarPack (just found with google)
