Hi,
I'm looking to purchase extension tubes for my Pentax K-r. I`m looking for more affordable alternatives than the Pentax branded version.
I`ve seen a cheaper alternative to buying Pentax branded extension tubes, like those by
Fotodiox .
However, I see that these don`t have any electrical contacts.
1) Without electrical contacts, do you need to have a manual aperture ring?
2) Without electrical contacts, TTL metering won`t work obviously - so how do you know what manual exposure to use?
If the above isn`t a good option for extension tubes, what other ones should I look at?
