12-15-2006, 03:04 PM   #1
slip's Avatar
NP-400 battery for the k10... which minolta camera is it for?
Hi
It is hard to find this battery without knowing which minolta camera it is used in.
if anyone knows, please let me know
I am asking radio shack but they need to know the camera model first
thanks
randy
12-15-2006, 03:10 PM   #2
peted's Avatar
I did a search on NP-400 and came up with heaps. It is used in lots of Minoltas including 5D and 7D.
Compare Prices and Read Reviews on Minolta NP-400 Battery for DiMAGE A1/A2 (8699330) at Epinions.com
This Digital Camera Battery is also compatible with the following models:
KONICA MINOLTA: a Sweet DIGITAL a-5 Digital a-7 Digital DiMAGE A2
Dynax 5D Dynax 7D Maxxum 5D Maxxum 7D
MINOLTA: DiMAGE A1
12-15-2006, 04:45 PM   #3
Used in the 5D and 7D.
12-15-2006, 04:52 PM   #4
slip's Avatar
Thank you both very much
randy
12-15-2006, 09:07 PM   #5
slip's Avatar
QuoteOriginally posted by peted Quote
MINOLTA: DiMAGE A1
Hi PeteD and thanks for the help.
the only thing is, all the batteries that I found where only 1400 and 1500ma, and pentax recommends at least 2500ma, as the real deal is 2700ma.
wondering if it will make a difference?
thanks
randy
12-15-2006, 09:18 PM   #6
clarenceclose's Avatar
The minolta battery is 1500 mAh
The pentax K10D battery is 1620 mAh
Both are the same voltage so basically you get 92.5% the shots with the minolta battery as you do with the Pentax battery.
12-20-2006, 09:25 AM   #7
slip's Avatar
QuoteOriginally posted by clarenceclose Quote
thank you very much, clarence and others
randy
battery, camera, minolta, tripod
Minolta np-400 vs. Pentax d-li50 battery HeG Troubleshooting and Beginner Help 6 01-16-2016 07:10 AM
K10 D is only good at 400 ISO Captain Pentax DSLR Discussion 21 07-22-2008 01:07 PM
Pentax D-LI50 & Minolta NP-400 Battery Chargers ? Confused Pentax DSLR Discussion 4 07-29-2007 06:02 PM
would using a Minolta NP-400 void your warranty? slip Pentax Camera and Field Accessories 6 01-18-2007 08:03 PM
can the Minolta NP-400 Battery be charged with the pentax k10 charger? slip Pentax Camera and Field Accessories 4 12-15-2006 06:22 AM
All times are GMT -7. The time now is 02:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
