Originally posted by cpk Thanks for pointing me back to the original thread. My questions are not answered in that thread, however, so my new thread still stands.
Well, I just ordered a couple of the double ended caps in question so I can post again in a few days when they arrive if someone doesn't answer your question first.
Actually, I guess I'll attempt to answer both your questions now anyway
As far as the coverage, the caps cover the entire bottom of the lens mount, including all the contacts. See the picture in this
post.
As for an issue with holding the contacts down while the cap is on, I see no issue there to worry about. The contacts are held in place with springs that keep the contacts extended. When the lens is mounted, or the cap is on, the contacts are depressed slightly and the spring compresses a bit. Either way the springs are neither in their fully extended, nor their fully compressed state. It won't have any negative effect on the springs in terms of weakening them to keep the caps on (much the same way leaving the lens mounted won't have any ill-effect either).
