Originally posted by Northern Soul I'm not so bothered about getting the adaptor off the lens as it will be my only m42. I was thinking if the cheap Chinese ones are any good I could just buy one with each lens and semi-permanently fix them on with super glue as I have no plans to start shooting film again.
Is it possible to remove the lens and the adaptor in one, or do you remove the lens from the adaptor and then the adaptor from the body?
This actually works since others have already done this.
You have to remove the locking clip out of these cheap adapters though since they tend to latch on or get stuck on the camera lens mount.
Without the locking clip, nothing would catch onto and get stuck on the mount.
Just use the rear cap of a K mount to tighten these adapters onto the M-42 lens. If tightened enough, it wont easily come off.
What you should be aware of though is, since most of these old lenses have a very dampened focus ring, you won't know when to stop twisting or when you have already reached the end of the focus throw or turn and you can accidentally unmount the lens off the body this way.
The trick to this, if you won't re-sell the lens, is to drill a hole on the back end of the lens to accept the camera lens mount lock pin. In that way, the lens would behave like a K mount lens.
Sorry, my drilling was done with a Dremel (a tad sloppy) since I didn't have a drill press then.
