I have two M42 bellows (US$20 and $30) and one PK bellows (US$35) so it ain't my problem.
But I just diddled with my hardwarez and came up with a couple solutions. Both involve ultra-cheap PK macro tubes, the kind that are about US$7 shipped. One solution requires a cheap non-M42 bellows of almost any mount; the other needs a cheap flanged M42-PK adapter and a cheapest M39-M42 adapter ring.
* Get a cheap non-M42 bellows, the kind with screw-down front and rear mounts. Nikon, Canon, Minolta, whatever. Unscrew the mount pieces. Drill matching holes in the mount sections from the cheap PK macro tubes. Screw-down the mount sections on the bellows. Voila! PK-M bellows!
* Take the female mount section from a macro tube set. Use contact cement to glue the M42-PK adapter to its back (threaded) side. Let it dry. Apply glue to the M42-PK adapter's threads; screw the M39-M42 adapter ring halfway in. Let it dry. Now you have a male-M42-to-female-PK adapter that is about 10mm thick. Mission accomplished!
How did you and your friend make an adapter?
