Originally posted by Sol Invictus I seen a a workaround suggested for getting your filters onto the DA 15.
I think it involved taking a cheap UV filter and knocking out the glass. The filter thread will extend the lens past the part of the lens hood sticking out. You can then attach whatever you want. And I don't believe this causes any vignetting problems.
good news. I wonder if a 49mm UV (glassless), step up ring, 52mm ND, 52mm POL and a screw in lens hood would cause vignetting. this would be a very thick setup even if it's a little wider compared to using the built in hood with 2 stacked filter especially if I went for the slim versions.
Quote: I don't know about the 15's hood, but if you are planning on buying both the 15 and the 35 ltds, go ahead and get your filters in 49mm thread. They both use the same size, so you will be able to use those filters on both lenses.
The problem is that I have 3 nice older lenses (including the K24 and K35) that take 52mm threads and I would like to use them. And it will be awhile until I consider buying the DA 35ltd (very long term planning). At the same time it's a PITA constantly messing with step up rings and filter sizes.
