On mine, the trigger voltage measures 3.1 volts. They are probably all the same, since they are relatively modern and weren't manufactured over decades like some flash models. However, you won't be able to use TTL mode on the flash (since the K10D only supports P-TTL). It appears to me that if you set it to TTL, it is actually behaving as though it's in MH mode. It will work fine with the K10D in MH or ML mode, but obviously you will need to either calculate the lens aperture from the guide number and distance, or take a trial shot first and adjust the aperture from there.
