Originally posted by wasser With the 15/77/31 zipped up the zippered area doesn't seem stressed imho, but I don't typically carry it like that. Also, I don't have metal caps on my lenses. I replaced them with 49mm plastic pinch caps.
Right again. I had my barrel extended on my 77. In fact, I discovered that you can fit all 3 FA's in there, and it's really not necessary to turn
any of them sideways. You'll have a little more room if you turn the 77 and have it in the middle position, but it can be done either way. It is pushing it, though I don't really see any stressed seams. The 15 and 43 are interchangeable, size-wise.
I'll
still probably stick to carrying the 15/43/77 in there, but it's nice to know that the "trio" can fit in there in a pinch. I could have sworn that the general consensus since that case came out is that the FAs (well, the 31) wouldn't fit. Huh!
