12-04-2007, 02:51 PM   #1
Montoya's Avatar
Max SDHC size for DL?
Hello All.
I am trying to find out how to tell if the 8GB Transcend SDHC card i bought won't work in my *istDL . I searched lots of threads, and didn't come up with anything. Sandisk's website says the max size for the DL is 4gb. So I did the only sane thing I could think of, and bought an 8GB model anyways. I popped it in, and the camera is reading 737 photos left to take (RAW). I let the camera format the card, and took a few photos, and everything seems all right. Will i need to take over 600 photos to see if anything negative (outdated camera pun?) will happen or should I safely assume that everything works fine?
And yes, I know it is safer to not keep all my photos on a big card, and instead use multiple smaller cards, but I could not resist 8gb packaged in a postage stamp sized piece of plastic. :-)
-Montoya
Just an update, I used the card just fine on my Trip to Puerto Rico. Though as I was past 600 photos on the card I did get slightly nervous. The Read speed on the card is life saver. Though I am sad. The card I bought for about $58 shipped can be had for around $38 shipped now on New Egg. Two months and *boom* big price drop. My poor money. :-) Next up, seeing if a 16gb card will work in the DL .
-Montoya
Last edited by Montoya; 02-19-2008 at 04:25 PM. Reason: Forgot to update this after my trip
12-04-2007, 04:59 PM   #2
If it can use up the space, then don't worry about it or try to get it NOT to work. I often load in larger cards in my cell phones than the listed maximum size and haven't had problems.
12-04-2007, 06:46 PM   #3
Mikhail's Avatar
If the camera reads that many shots, and with quick math thats roughly how many you should be getting you should be A-okay!
Thanks
My 2GB cards take a little less than 200, so sounds about right!
camera, card, dl, max, photos, sdhc, size, tripod
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Max paden501 Post Your Photos! 3 12-03-2008 06:23 AM
Max size for an SD card in K10d russblack Pentax DSLR Discussion 1 03-11-2008 07:47 PM
Max size sd card for k100d/k10d ? shane Pentax DSLR Discussion 17 09-18-2007 01:12 AM
K100D Max Print Size? Jimsi777 Digital Processing, Software, and Printing 6 09-10-2007 10:00 PM
All times are GMT -7. The time now is 04:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
