12-05-2007, 07:54 PM   #1
filmamigo's Avatar
DIY Portrait Bracket
I have occasional need for a portrait bracket. I don't really want to either buy a new tripod head or invest in an expensive bracket. So I made my own. Having looked on the web, I didn't see anything this lo-fi. (I did see one DIY bracket that seemed to require a machinists certificate and unlimited sources of aluminium blocks for machining.)
Parts:
One tripod and with quick release plate -- I used a spare Bogen 3130.
Right angled bracket -- I used one with three holes predrilled in each side.
1/4" bolt - 1" in length
1/4" wing nuts - (qty. 2)
I seperated the quick release screw from the quick release plate. The screw I reuse to attach the camera. The plate I use to attach the whole bracket to the tripod.
Because I attached the plate using a wing nut, it is simple to move the plate to the other side of the angle bracket and switch the mount from portrait to landscape.
I hope this is useful for someone else!
Pictures attached.
12-06-2007, 10:04 AM   #2
Improvement suggestion
May I suggest a couple of improvements.
You would have been better scrounging up another QR plate and mounting the camera body more securely cradled tightly into the corner of the L-bracket. This way, no screws to undo, less chance of fumbling, quicker to operate, and more stable.
Just my £0.02P, hope it helps.
12-06-2007, 10:21 AM   #3
I guess that I'm lucky with a sturdy pan head on my tripod.
I'd run every piece through a grinder to remove all those sharp edges. Even a file should work.
And do paint it black, it'll look more professional.
I might be trying something very similar to mount a flash on my medium format film camera.
12-06-2007, 11:15 AM   #4
filmamigo's Avatar
Good tips, thanks. The second plate would be a big improvement, I will see if I can scrounge one up.
Ground down and painted black would be a definite improvement. This is the $2, 2-minute version! Really just a stop gap -- I have my eye on a new Manfrotto with the centre column that swings around.
bracket, diy, plate, portrait, release, screw, tripod
When you take a picture in a portrait shot do you rotate it back to portrait and save rustynail925 Troubleshooting and Beginner Help 24 08-22-2010 08:29 AM
DIY Horizontal Flash Bracket for Light Stands atupdate Do-It-Yourself 0 07-04-2010 07:53 AM
Portrait pictures, is a bracket necessary. Kirk Smithson Troubleshooting and Beginner Help 10 12-10-2009 07:40 AM
DIY Ring flash bracket tcdk Flashes, Lighting, and Studio 2 05-11-2009 02:09 AM
Portrait, Self-Portrait and a Bonus, all in one shot! Buddha Jones Post Your Photos! 7 05-07-2007 05:52 AM
All times are GMT -7. The time now is 12:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
