Originally posted by Peter Zack Joe, You may very well be correct on the T mount. But I have 2 that fit my bellows perfectly. I ordered them from Henry's in Canada and had asked for a "T mount to fit M42" I've been using them for several years on a PZ1p and now the K10D.
I've heard but not used, that there is another version called a T2 mount. Is that the different thread?
I am referring to the threads that connect to the lens, not the M42 threads that connect to the body.
The thread diameter of a T,Mount adapter is the same, it is the pitch of the threads that is different.
I have never seen a T2,mount, and have no idea what the thread pitch is.
The T,Mount adapter was originally designed to adapt the camera to a telescope.
I have seen many T,Mount lenses that have been directly attached to the Pentax M42 mount, and in many cases has caused problems.
Cross threading or getting stuck on the camera is only two of the problems that could arise, these lenses are designed to be used with a T,Mount adapter, which acts as a spacer as well as an adapter.
This will bring infinity focus up to where it should be. Otherwise your camera will not focus as close as it should.
You should never take a chance on damaging your camera in this manner.
The worst thing that could happen is that small flakes of metal could get into your camera. If you are using a digital camera, small flecks of metal could short something out.
Although if you do not care about your equipment, please be my guest, Take whatever chance you want to with your equipment. Just don't do it with other people's equipment
joe1955
