Originally posted by jerryleejr
I am kind of in the same boat, Just started looking for a tripod and head, I know the skies the limit as far as price goes but I just want to know after the tripod and mount head what else should I be looking for? Oh and if this needs to be its own thread let me know just didnt want to hijack this one.
JJ
Having just purchase a second expensive tripod after I decided I didn't like the first one that I bought that was also expensive,
trying hard to get what you want the first time is to be reccommended.
My special issue was a very heavy lens. Things you need to figure out is how much weight you need to support because
you can get them for different weight classes. The really light tripods are also really flimsy, and they don't really accomplish what you are hoping for if you have a heavy long lens.
After deciding I didn't need a quick release, I immediately regretted that, because I wanted my camera loose in a hurry
about the first timeI put it on the tripod to use, and by the time I got it unscrewed it didn'tmake any difference any more.
so I am an advocate of a quick release.....
Also If you want to do a PAN or video because of its potential to move on multiple axis when you release it.
I ended up with a Manfratto with a head with separate controls/locks for each axis. It has big levels on it, and if you level it up
when you set it up, you can release it on any axis of your choice and move/pan while the other axes remain locked. I don't think this is exactly what happens with a ball head.
as nearly as I can tell the most stable support for your camera is a large block of Concrete and a beanbag, and anything less than that is a compromise between stability, and portability and you sort of need to set your priorities.
