Originally posted by dales (snip) what memory card should I be looking @ that I can get for not over $50-75.00? (snip)
A normally functioning memory card should not cause delays approaching 30 seconds ("1/2 min"). Anyway, I use
Panasonic 2GB Pro High Speed (Class 6, 20MB/s) SD memory cards. In fact, I've used a handful of them in seven different devices (two cameras, PDA, card readers, GPS, etc) for several months now without problems, so they're compatible with most devices (not all cards are) and are very reliable with a lifetime warranty.
Matsushita (the parent company of Panasonic), SanDisk, and Toshiba jointly developed the SD and SDHC memory card standards. Lower capacity cards (3GB or less, called SD cards) work with either SD or SDHC card readers, while larger capacity versions (4GB and above, called SDHC cards) require an SDHC card reader. The speed class rating (Class 2, 4, or 6) can be used with either SD or SDHC memory cards. The Pentax K10D is both SD and SDHC memory card compatible, but the card reader within your computer may not be SDHC compatible.
By the way, B&H normally has
these 2GB Panasonic cards for $34, but they're out of stock at the moment.
stewart
