Originally posted by dmadden I have the 190xbpro, its light enough to carry everywhere. I'm only 5ft 9" so the height works for me, but its still a little short at times. If your taller go for the 055XPROB, i would'nt get the older 3021pro because the 055 is the newer version in that line. I also use the swing around boom a lot, for macro.
For macro work, I carry a Benbo Trekker. It has to be the most awkward tripod in the world to set up. There is a single locking lever that releases the sliding boom and all three legs at the same time. Everything flops when you unlock it.
On the other hand, there are no restrictions as to where the legs are or at what angle they are set, and this is independent of the boom. I have set this thing up on the side of a hill with legs in all (well, three) different angles and heights, and the boom slid out sideways.
The other thing the Benbo has that I have not seen on other tripods is that the largest leg sections are on the bottom of the legs, and slide up over the top sections. Whoopee! no mud in the leg slides!
Except when you step into a big hole in the swamp, of course. And don't expect any sympathy from SWMBO - she will be laughing her head off at you, helplessly, and not helpfully, while you try to get your shoe out of the sticky mud after it came off your foot while holding the tripod and trying not to soak your non-weatherprood MZ-S and 400/5.6 and 1.4x and still get out of the swamp. Whaddaya mean, I'm speaking of personal experience?
I didn't get the shot of the heron either. Expletive deleted.
