Originally posted by baj SOldBear, you don't mean that a T-mount adapter would be exactly the right diameter to fit the bellows, do you? (I don't know anything about T-mount and whether or not a bellows would like use the same specifications.)
No. I tried the T2 mount with the Pentax pK-mount bellows (similar to the M42 bellows you referred to in your post, but with pK mount). It doesn't fit.
Interestingly, the
inner ring of the T2 adapter fits the bellows. If only I could attach 2 inner rings of the T2 adapter back to back together....
Note that whatever adapter you use, it has to allow a way for the camera body to be attached to the bellows without rotating. Many times something gets in the way, preventing the camera body from turning.
Originally posted by baj The attraction of these old Pentax bellows is that both ends move on the rails (so no need for macro focusing rails), which isn't true of any of the cheap new ones I've seen or even most of the old ones. And I suspect that they're nice and solid.
You're absolutely right. The Pentax bellows are very nice and solid. Before I bought a macro focusing rail (which is part of a Minolta bellows kit), I modified the Pentax rail to use it as a macro focusing rail for a while.
