Originally posted by fisheye freak Pentax cameras are probably the best at handling the cold. May pay to tweak the aperture ring a few times before shooting to make sure the lubricant has not congealed. definately taking an icy cold lens back in to a warm room will invoke condensation, with long term implications in the fungal area. The freezer bag or zip-lock is a good idea. The old 35mm film cameras developed problems in very cold conditions- the shutters slowed down causing overexposure and the lenses did not stop down fully, also leading to overexposure. Luckily, not too many of the photos were ruined this way.
We happen to know that K10ds work darn near naked in *space,* actually.
One thing, though, OP, is that in frigid temperatures, your worry for condensation/damage, is usually about *temperature changes...* Even an ordinary nylon-on-padding camera bag will prevent undue condensation issues as you enter a *warmer* space: they seem to do just enough to slow down the temperature changes as long as you put the rig *in* there* before entering a warm space, and just leave the rig in there for a while, the colder you think your camera has gotten. As long as you slow down the temperature *changes,* you're probably OK.
As for actually *being* in the cold, you will want to be keeping some batteries warm next to your body: they *will* lose power and efficiency if they get cold.
Also remember the plastics will be more brittle in deep freeze, so don't go knocking stuff around.
As a rule of thumb: *any* time you are worried about your gear, moderate the extremes, don't try to hermetically seal against them.
