At the risk of sounding rude, may I make a suggestion? Leave the camera out of the box, put a single layer of tissue inside the box next to the seal (cut a facial tissue into strips), and seal the box as you would before a surfing run. Find a pool with a dive tank about 5m (15ft) deep - a pretty standard depth. Either have a scuba diver take the box to the bottom, or tie a fairly heavy weight to the handle along with a long cord (like 7m or more). Send that box to the bottom and just let it sit there for say 20 minutes.
5m is 1.5 atmospheres of pressure. If it leaks in this test, I would NOT trust it on a surfing run. When you bring the box to the surface, dry the exterior then open it and examine the tissue. It should be easy to determine if there have been any leaks.
