Originally posted by Nachodog Works great, but for some reason the AF won't work. I know my circuit is good and my connections are good.
I just can't get my K7 to AF with the Remote Cable Release port.
If it's not AFing, then it's not working great now is it?
I'd suggest checking your wiring and connections, and then checking it again; use a multimeter and check to make sure the contacts are right, and there's no wires touching where they shouldn't be, you've wired up the switches correctly, etc, etc. Otherwise, there's a slim chance that the actual cable release socket in the camera, but my bet would be your remote.
