Bellows are great. The SuperTak 50/1.4 is great. But the SuperTak isn't necessarily great on bellows. It won't be *bad*, it just won't be up to full potential. For bellows work, whether macro or close, we generally want a different standard of sharpness. Luckily, such sharpness is plentiful and cheap: enlarger lenses (ELs).
Many gruesome details can be found here:
https://www.pentaxforums.com/forums/pentax-lens-articles/152336-cheap-macro-b...lose-work.html . But I'll cut to the chase -- my recommendations:
A SuperTak 50/1.4 for US$100 is about right. This is a favorite general-purpose low-light and head+shoulder portrait lens. But it will be limited/awkward on bellows; it will only focus VERY close. Better to get cheap M42 macro tubes, and stop-down the SuperTak to f/4 or so, and shoot at a little distance.
You can find decent (new or used) M42 bellows on eBay for well under US$50. Attach it to your camera with a cheap safe wide-flange NIF (no infinity focus) M42-PK adapter. Use that same adapter on the macro tubes I mentioned above -- working close, infinity just doesn't matter. And you can often find decent enlarger lenses for under US$10 each. Some Japanese and German ELs are M42, but most have M39 thread, so they'll need a very cheap M39-M42 adapter ring. Many USA-made ELs have non-metric or just plain weird mounts. I buy cheap plastic M42 body caps, ream holes in them, and mount the lenses that way.
Ah, what kind of EL to look for? Starting off, brand doesn't matter. Even cheapest ELs aren't bad. More important is focal length. The shorter the lens, the closer you must work. For studio shooting, I'll use 35mm or 50mm or 65mm. For portraiture, I like 75mm (usually on tubes). For general work, I like ELs in the 100-160mm range. 100-105-110mm are my favorites. They can focus from very close, all the way out to infinity.
That's enough to get you started. Read the article when you get a chance. Have fun!
