03-07-2012, 09:01 PM   #1
jbarry's Avatar
olympus OM 20 lenses
I have read all of the old threads on here and was wondering if there were any new miracle ways to use OM 20 lenses on my Pentax Kr?
03-07-2012, 09:19 PM   #2
RioRico's Avatar
I think the OM-20 aka OM-G used standard OM-mount lenses. I've modded a few of those for PK mount. Tools: a Dremel with metal-cutting blade (sorry, I don't have the blade number with me at the moment) and maybe small screwdrivers and that's it. Trick: taper the lens bayonet blades back about 10mm so they fit under the PK mount lugs. Security: cut a slot (about 1.5mm deep and wide, 5mm long) or drill a hole (1.5mm wide) for the PK locking pin to engage.
Before trying this, spend US$10 (or less) or a cheap PK macro tube set. Set the OM lens base into the macro mount and you'll see how the bayonet blades and mount lugs interact, and where and how much to shave from the blades. After tapering the blades, blow away any metal dust. You may want to jam or tape down the lens' stop-down button so you're not always shooting wide-open. The lens can still be used on OM-mount cameras. If such retro-compatibility isn't needed, it's easy to remove the lens base and remove that stop-down button, then replace the base.
This is the cheap and easy way. If your OM lens is rare and special, you could spend about US$100 for a Leitax adaptation. If the lens is special AND you want to go ahead with the lens-chopping anyway, get a cheap OM lens to practice on first.
lenses, olympus om, om, tripod
M43 Focus Assist on Olympus e-pl2 using Pentax lenses with Adapter tnb Non-Pentax Cameras: Canon, Nikon, etc. 3 03-04-2011 07:21 PM
For Sale - Sold: LOTS of Olympus OM Lenses KmountShooter Sold Items 11 07-10-2009 06:40 PM
For Sale - Sold: Olympus OM lenses drjaxon Sold Items 7 03-12-2009 08:22 PM
Adapter for old Olympus lenses? tlavoie Pentax Camera and Field Accessories 5 01-05-2009 12:06 PM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
