Originally posted by bdery Thanks for the opinions. Honestly, while I understand that good craftsmanship costs money, I work in an environment that allows me to know manufacturing such a thing as a ball head does not amount to 300$ That's why I'm willing to pay a no-name brand some money if their reputation is good.
No kidding. None of the higher-end ballheads (Kirk, RRS, Markins, Acratech) cost anywhere north of $50 to make and distribute. If they did, those companies wouldn't be in business (or have a profitable reason to be)! However, that makes me think that the HorusBennu probably costs under $10 to make and distribute (for the same profit reason)... and lower labor/overhead costs in Korea (or more likely China, even if it's a Korean brand) is not the only factor that plays into it.
So, where's the difference, and does it matter to you? That's the consideration...
My thoughts:
- Materials: almost certainly the HorusBennu isn't made from the same alloys as others, but that might not make a huge mechanical difference (softer alloys are easier to machine as well)
- Mechanics: my favorite "cheap ballhead discovery" was that a (long discontinued) Benro ballhead used a pointed screw to "hold" the tension by actually
screwing into the soft metal of the ball!
- Design: if it's a knockoff, there's almost no cost from designing or improving something.
Markins was solely an industrial pump manufacturer in Korea until the owner started knocking off Arca Monoballs, but they've improved the basic design (strength to weight, locking, etc.) to a degree that Arca never did. Their prices rose along with this (see also Feisol tripods)!
Again, this is all academic if you're okay with "the risk" of a $50 ballhead. I think the device itself is so common now that $50 isn't unrealistic for a decent device, but there's a risk that it won't lock well, wears out quickly, leaks grease, has a screw fall off, etc. Of course, the same things can happen with RRS ballheads, but are much less likely and will be quickly handled by RRS (since that $300 includes warranty service).
