Originally posted by theflyingjocksman The sole use of the bag would be for a long days hiking and keeping the camera and equipment safe at the same time probably only going to be 3 lenses long telephoto, kit lens and a 50mm spare batteries and maybe a tripod but most likely a monopod. Enough storage space for drink pack lunch and a coat/waterproof trousers. It will not be used in cities etc I will just stick to my shoulder bag for cities and zoos etc
Ok, from that persoective, there are a coupple of options, The smallest pack I have, and I think the smallest that lowepro make, that can hold a tele when mounted is the microtrekker 200. while the size is about right for what you need, there are a couple of potential issues based on your explained use.
the biggest beef I have (maybe the bag has been redesigned since i got mine) is that the shoulder straps are not truely adjustable, (they can be lengthened, but you cannot move the pack up and down on the straps) As a result, unless you are really short, you have one of 2 options, either you don't use the waste / hip belt to put load on your hips, and have the chest strap in the correct location, or you use the hip belt, and forget the chest strap as it is around your neck.
The other issues are,
- that it does not come with a water proof cover (so if you are caught in a storm, you get your gear wet, This can be solved with an aftermarket cover.
- it lacks side canteen net pockets, so you either add on an attachment or clip the canteen to the straps. I would recommend against putting the canteen into the interior of thebag in the event it leaks.
My concern with strap arrangement is that if you really intend to hike, having the loaed on your shoulders can get tiring.
there are some newer hiking daypacks, that with padding might be better than a camera pack.
