Originally posted by Clicker LOL sorry "read too much into that one", yes the FastenR fits in any of the thread openings on the plate (there's a new plate coming to market soon/might already be out) BUT it hangs arwardly/angular/diagonally off the body from the protruding openings...the openings for tripod plates make a better "direct" connection but defeats the dual mount camera/tripod plate purpose....i'll have to play around with that one a bit.
I put the massive & heavy Carry Speed plate back in the box, I don't see ever using it again. I would rather just remove the ball connector for tripod mount. As to the other stated advantage, maybe I have a different grip than the designer of the Carry Speed strap, because I found the offset ball pin was in my way in vertical orientation, and only a bit awkward with the pin centered.
Originally posted by Clicker You might want to wait for this newer plate though, it seems like it might be a better direct mount for the fastenR.
From the blurb on the website, I wonder if the new plate will remain as an extra cost option?
Originally posted by Clicker The current plate is too close of a design to the Spider Holster's plate imo, this newer plate may be safer against any pending lawsuits
I read somewhere that they were co-developers and the patent is shared between Carry Speed and Spider Holster.
I had the CS-PRO out this weekend. I was pleased with how it performed, it's a versatile system. My only complaint is that the ball squeaked in the socket as I walked. When I got home, I added some silicone lube to the ball, which resolved the issue.
My main interest in purchasing the CS-PRO was the ability to change from a sling to a wrist strap with ease. It definitely allows that. I ended up screwing the CS ball connector into an Arca plate that was attached to my battery grip (not offset). I didn't need the Arca plate, but I have it permanently mounted to my grip, so I just left it in place. I like using a grip with a long lens, because it's comfortable to hold, but I rarely used the grip in the past because of the added weight. With a sling, the extra weight is barely even noticeable.
To change to the wrist strap, I just removed the grip from the K20 and screwed the wrist strap into the tripod hole on the bottom of the camera. This was quick and easy, needed no tools, and the bulky grip stayed with the sling. There are a lot of ways to use the CS system, I will try some other configurations, but all in all, I am completely satisfied with my purchase. Thanks Clicker, for bringing this to my attention. This thread was the first time I had heard of Carry Speed.
