Thanks to 'cmohr' (
https://www.pentaxforums.com/forums/pentax-camera-field-accessories/174187-my...lots-pics.html) I got inspired to create my own setup, because I frequently alternate between Tripod/Monopod and Hand-held Landscape/Portrait modes during a single photo session. I thought I'd shop around (on eBay) and being a ex-fitted and turner in the aluminium industry, I came up this my version, within my budget.
I initially looked around at what is compatible with what, most dovetail QR systems are Arca Swiss compatible with each other, with a 38mm wide clamp systems.
Then I look around for a suitable Ballhead for my
Manfrotto 679B monopod (which if needed I could use on my
Slik Pro 500DX Tripod) within a descent price range (under $100) and big enough to support my maximium weight. I purchased a
Benro B-1 Ballhead which came with
PU-60 Plate for $106 with free delivery
I then spent a coulpe of week trying to find a 'L' bracket to suit my K-7
with battery grip (until resently I didn't find one in existance) so I made my own out of 100mm x 6mm 6060 aluminium flat plate. I was happy I got the bend right the first time to what I wanted
and here we have it.
Battery compartment opens and closes with hitting, the only problem I have created is access to the side compartment, maybe on version two I'll work it out.
This also all started with my dissatisfaction with the quick release plate that comes with the Slik tripod, after a year of heavy use you start to get movement once clamped. So I purchased a
SunwayfotoDuo-Lever 50mm Adjustable Width Clamp and machined off the original clamp and bolted the new one on.
My setup with the Sigma 70-200 + Kenko 2x TC on Tripod and Monopod
I also purchased some D-ring hinged 1/4" tripod/camera screws to attach this new system and still be able to quickly change over to my
Black Rapid R-Sports Sling
For those who are interested, as I said earlier. Someone has finally manufactured a 'L' Breacket for the K7/K5 with Grip. Look for the
Mestos PD-K5HL L Plate on eBay, it's about $150 US with free postage (I know someone else has already mentioned it some here already).
Next I'll try to work out how to make a Gamble Head, because there is no way I could afford to buy one, so I will see how I go?
