05-02-2012, 03:03 PM   #16
emalvick's Avatar
QuoteOriginally posted by Giklab Quote
Try this Camera Tripods, Head & Accessories By 3LeggedThing.com
The 3LT Brian goes to 2,04m
I haven't really looked into it much, but I had seen this brand on B&H... The thing I guess I need to look into is the quality and reviews of those tripods. It is a new brand to me that I've seen very little about with respect to the forums here and elsewhere. They are appealing, but at this point so are the Feisols at a similar price point. I'll also have to look at the Oben's, which look to be a house brand for B&H.
05-02-2012, 04:29 PM   #17
SpecialK's Avatar
The inexpensive Dolica AX620 does not use the crappy geared crank, but instead has a sort of winged ring wedgie thing that seems pretty firm.
05-03-2012, 08:05 AM   #18
rvannatta's Avatar
QuoteOriginally posted by emalvick Quote
Actually, I think that is the tripod I have, and I have found that at 1 second everything is fine... At 3+ seconds, everything goes bad. I can get 30 seconds without the colum extended, which is probably fine since I wouldn't be stooping very long in that case anyway. I was just a bit frustrated at some 6 second shots I was trying to get last winter at night that ended up bad. In running through a gamut of 1 second to 15 second exposures, I could see with that tripod where 3 seconds was a magic number for image quality (obvious vibration).
I truly believe that one of the keys to a column extension that doesn't wobble is a tripod with cross bracing between the legs and the column.
without this bracing the column is only scantly supported in one place --- and 1 point mounts are wobbly.
the cross bracing makes them much more difficult to fold up but specifically addresses your concern of being able to extent the center column.
aluminum, capacity, center, column, head, idea, inches, tripod, tripods, velbon
Tripod and monopod options vs height TonyL Pentax Camera and Field Accessories 4 02-04-2012 04:38 PM
Subject height on a soccer field at 300mm FL vs position dosdan Photography Articles 3 12-16-2011 10:09 PM
Average height Nesster General Talk 5 04-29-2011 10:37 PM
Height of Arrogance? JohnInIndy General Talk 48 03-17-2011 09:46 AM
How do you get the tripod height just right, most effectively. pcarfan Pentax Camera and Field Accessories 2 02-14-2009 05:16 PM
All times are GMT -7. The time now is 06:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
