01-17-2008, 07:13 PM   #1
'F' remote control ?
I want to do some night work w/my K10D. I have a tripod. For open shutter, set the camera to 'B', does the 'F' remote control open the shutter when 1st pressed & close it when the remote cont. is pressed a 2nd time?
01-17-2008, 07:22 PM   #2
FotoPete's Avatar
You have to hold it unfortunately haha. I'd look for some of those custom remote builds where there is a kinda lock to keep shutter open till you flick it off.
01-21-2008, 09:40 PM   #3
ChipB's Avatar
Dales, another option is the CS-205 remote switch - you have to plug it in (it's not wireless) but it does lock in position so will hold the shutter open for however long.
And, you can also use one of the wireless units found on the web - I bought one of these Wireless Shutter Release Pentax K10D K110D K100D Cs205 - eBay (item 230201184310 end time Dec-15-07 04:32:33 PST) and it seems to work just fine - I haven't used it extensively, but a quick couple of tests gave me the results I expected.
And, finely, a comment about the Pentax Remote Switch "F" - to use it (at least on my DS) you go into 'Function' and select the remote - this times out after 5 minutes so is not particularly useful for wildlife photography (not to be confused with the camera [I]power[I] time out).
I have all three - I'd use the CS-205 for nighttime and the wireless for any bird or wildlife work. Just my 02!!!!
01-21-2008, 11:31 PM   #4
Hi dales
Try these two links for further information, which should explain clearly how the Yong Nuo functions:
https://www.pentaxforums.com/forums/84720-post29.html
https://www.pentaxforums.com/forums/84728-post30.html
Best regards
Richard
control, shutter, tripod
K-x remote control Gary G Pentax DSLR Discussion 22 01-02-2011 09:50 AM
Remote control F Mojtala Pentax Camera and Field Accessories 2 11-02-2010 03:58 PM
Remote control for Pentax: PocketPC app. (alternate to Pentax remote) dragonfly Troubleshooting and Beginner Help 4 08-12-2010 10:22 AM
Remote Control for K-X Calcinator Pentax DSLR Discussion 0 05-02-2010 08:25 AM
Remote control walsh Pentax DSLR Discussion 12 08-26-2008 02:22 PM
All times are GMT -7. The time now is 11:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
