Originally posted by excanonfd This lens isn't going to used hand held too often, though I am sure we'll try - often. Tripod will be a requisite equipment but yours is far too light for this. I have an 055 with 410 Junior Geared Head or the Dolica CF with 488 ball head. For absolute stock still shot, I will use the former but the reduced size and weight of the latter set up is good for hiking, although the shortness of the legs are problematic for my back. At the minimum, I will be carting around the 679B monopod to shoot with this lens.
Thanks for the tripod links, I will definitely consider something better.
I tried my Quantaray QSX-9502 last night, and it is a lot more stable. However, I also tried with the TC, and couldn't get any sharp pictures
It is really hard to figure out the subject and focus when all you see with your naked eye is pitch black with a bunch of dots for lights. The right angle finder eyepiece is really critical. Focusing with live view doesn't really work well enough in those conditions unfortunately, even with the magnification option. You would need to have ISO 25600 enabled for the live view preview which doesn't appear to be possible. The K-r also has quite a delay in the live view, compared to the T3i.
I have attached a few handheld shots taken today.
The first five are were taken from my balcony. The bridge is the Dumbarton bridge over the SF bay, 21 miles away bird's eye view.
There was a lot of sun, not a cloud in sight. Probably too much. A hood might have helped.
There was rather a lot of wind which interfered with my ability to stand still, let alone hold the camera still. But I used ISO 1600 and very short exposure times.
I also have a handheld shot of the back of a car with a very clear license plate from about 150-200 ft way, but didn't want to post that one for privacy reasons. Not something you could ever read with your naked eyes.
As you can see all those shots are rather washed out. I only spent about 15 minutes trying, will have more time over the weekend. I am sure I can do a lot better with a tripod, not sure without.
Edit: I am not sure, but I think that I may have had the 2x TC on the lens when I took these handheld shots from the balcony. That would certainly explain much of the reason for the softness.
Starting with the paper which was taken indoor, the shots are from my office campus, all outdoor. These are at 800mm, without the TC.
It took 3 tries to get the bricks in focus, but I am amazed as the sharpness I was able to get when I succeeded. It looks good even at 1:1.
Quote: That's a very good shot of your cat - so far, I am impressed by what this lens can do.
Thanks ! I actually have about a dozen shots of him which all came out very fine, just posted the one I thought was best.
