Originally posted by mysterick When using my AF540FGZ and AF360FGZ as remote slaves on channel 1, I am unable to set the modes to P-TTL, only A or M.
I've noticed this a couple of times with my AF540, and I was completely mystified by it to start with. There are only so many times you can go through the instructions one line at a time, have it still not work, and not end up thinking you're either mad, or something's not working right.
However, putting in freshly recharged batteries has seemed to cure it, despite the batteries in it being perfectly capable of charging the flash to the point of lighting the test light in a reasonable time, and discharging (in A mode on the hot shoe) to produce a perfectly well exposed photo.
I'm far from convinced that this really is the root of the issue, though - it's not as if the problem reliably reappears as soon as the batteries get a bit tired.
