Originally posted by Waj K Maj I am stuck on finding myself a flash diffuser can anyone tell me where I should be looking and what type(s) currently I own a Sigma EF-610 DG SUPER and it just creates too many dark shadows and bright spots up close!
Originally posted by Waj K Maj Yes perhaps my settings or flash config needs work
One thing that one should never forget is to use a fixed ISO when using flash. Your camera might increase the ISO first and next add the flash. At shorter distances this can easily result in an overexposed subject as there is a minimum flash duration (and hence a minimum amount of light that will be emitted).
And the other thing is that a direct flash (even with diffusers) can theoretically only illuminate properly at one distance; in front of it will be overexposed, behind it will be underexposed. In practice you will not see a problem within certain limits. Bouncing will prevent this. My problem is that I often shoot outdoors, so the sky is the ceiling which does not really work
AF540 with slide-on diffuser
