Originally posted by steve1307 For the support weight rating, what is it that everyone says? Go for at least DOUBLE the weight of your heaviest load as a minimum.
I hadn't heard that before. My first tripod I bought in 2000 cost me a lot more than this one I got yesterday, it was a Bogen 3221W, a wilderness tripod, center column that I could remove in order to go low to the ground, it was heavy fully loaded, tripod, coupled with pistol grip head, and either my K1000 or ZX-5n. But I was a lot younger and a lot stronger back then and had no problem carrying it up a mountain to shoot.
If I could find a way to stop the leg creep, I'd just keep this Bogen I've been using. It's sturdy enough to handle just about any rig. Though I want to get another head, this small head I have worked fine until I got the Samyang 100-500mm, now the option to tilt the camera vertical, has become a nuisance because it does not tighten down straight back in its original position, my camera isn't level, it tilts down. I don't know how to explain what it does any other way.
