Originally posted by Anvh I forgot to mention but the yunguo does have a mode to ignore the P-TTL flashes right?
I don't know, but it doesn't matter when using manual mode on both flashes with the Yungnuo as an optical slave, does it? Because there won't be p-ttl flashes? I only intend to use both flashes together in those circumstances.
Mister Horrible, thanks for the suggestion but it's more money than I can afford to spend.
Pity the older lenses can't do p-ttl, but I'd not be using them in circumstances that truly require it like events since they can't autofocus, so that's something I can live without.
