I did a lot of research on the Ebay triggers before I finally bought them, and I decided the cost was worth the purchase.
Having got them, I immediately bought new batteries and chucked the one that came with it. I also put a little extra solder at the solder joints on the inside. Also, I carefully superglued the PC sync ports on the backs of the receivers because I had read they were very fragile.
When I started using them, they worked perfectly. I have the 16 channel design (RF-616) and occasionally they work better on some channels than others, but I really haven't had any problems with misfires.
The only thing that would be better for me is if the range was longer. I start running into problems past 30 feet or so. I have this link:
Increase effective distance on 'ebay' flash remote trigger transmitter with antenna - Instructables - DIY, How To, art, tech
on my mind, but as of yet, I haven't done this. Soon, I think I will buy a couple of more transmitters so if something goes wrong, I have something to fall back on.
Bottom line, until I can afford Pocket Wizards, these will have to do. And they have done just fine for me.
