Originally posted by pentagor Thank you both for this. Yes, since they are 52mm, I would use them on my kit lense.
I was just wondering, what is the magnification of the macro diopter. Do you think it is 1:1?
Maybe we can merge threads with this one
https://www.pentaxforums.com/forums/pentax-camera-accessories/19198-close-up-...-question.html
See my post, which outlines the math behind close up lenses, impact on maximum focusing distancem and magnification ratio.
the OP on that thread was looking to go 1:1 with 28mm lens. in my opinion that is just too short, and the same holds true (but to a lesser extent with a 50mm. it is just too short, because 1:1 implies equal object to lens distance as lens to focal plane distance. with either the 28 mm in the other thread, or the 50mm in your thread 1:1 with close up lneses is not the best way forward. with 50mm lens, 1:1 can be achieved with a 50mm extension tube, and the subject at 100mm from the front of the lens.
I have played with +1 and +2 diopter close up lenses on my 135mm, and had a lot of fun, between 1:8 and 1:4 working between 1 meter and .5 meter from the subject.
With macro, my view is the further away from the subject, the better. therefore you are better to start with a longer prime lens. I have a 100mm marco, and the 135mm which I use with both extension tubes and close up lenses.
